Successful 5 sat hookup | SatelliteGuys.US
tyler95023
27
Hollister, CA
I was able to successfully hookup 5 satellite after surfing this forum getting several ideas.
Here it is:
Dish 1000+ kit (110,118,119,129) to DPP44
Port 1- power inserter to 211k
Port 2- 211k
Port 3- 612-ran to DP21(sat 1 from 61.5 on DP dual/out 1)sat 2 out to tuner 1
Port 4- 612-ran to DP21(sat 1 from 61.5 on DP dual/out 2)sat 2 out to tuner 2
Check switch ran successfully for 5 sat locations on both tuners.
(brain asplodes)
What happens when a channel is available on multiple sats, how does the box pick?
in most cases of the HD channels it defaults to 129 if there are multiple sats with the same programming
Its not like the old days when someone had a dish for 148 and one for 61.5 and the channels showed twice in the guide :)
AFAIK, 5 is the maximum supported. The rumored 6-port switch had not been canceled as of last year, but it also hasn't appeared and I'm hard pressed to come up with a case for it beyond getting the 5th sat to 4 receivers and avoiding a cascade.
My question is WHY?
61.5 and 129 are virtual repeats of each other.
obviously you havent been around long enough.
in the past people competed to see who be the first to see a new slot go hot, who had the biggest dishes for greater rainfade resistance.
satellite tv can become like a virus, it takes over.
honestly I will miss the tech side. its been fun, 13 year hobby:)
My question is WHY?
one reason I can think of is if you subscribe to the multi-sports pack there are some RSN"s that are in HD and are ONLY on 61.5 or 129
also when 129 was that crappy Echo 5 folks used 61.5 for HD and used 129 if they absolutelly needed to (like when locals were on there)
That is exactly my reason thanks, Iceberg.
> I wish they'd put something up in the 148 slot so Alaskans can stop aiming through trees.
hmm come to think of it, even with a sat in space 148, I'm still sitting on the top of the world
Dish Remote DVR Access iPhone APP
Questions about NBA League Pass for TV
