Sunstar ST-5000HD DVB-S2 HD HDMI receiver for $44 shipped | SatelliteGuys.US
Bob2011
526
2
Hudson Valley NY
New member Xourque just mentioned this new box in another thread but I decided to break it off into a separate discussion.
I have never seen one this cheap shipped from the USA before. It is so cheap it makes you think there is something not right with it. I have heard of Oceansat before and have seen their Craigslist postings for cheap FTA equipment in the NYC area.
If you look at the listing it almost pokes fun at the MicroHD and Openbox. It appears to use the same chipset as the MicroHD or Skybox.
Is it too good to be true? Is it a clone or fraudulent copy of a legit receiver?
http://www.oceansatellite.net/product/satellite-fta-receiver/hdrcvr.html
Yikes! Very unimpressive specs! SR 4-<45 :( 4:3 only
Definately "You get what you pay for" and this one isn't much
It may work on some channels. I bet the software is just a nightmare. Order one take a $44 risk.
yeah but
Wide Symbol Rate 4~45 Mbps
so a lot of those news feeds wont be picked up then as they use 3978
also it claims HDMI yet the picture shows a/v cables??
also in the specs
PHYSICAL CHARACTERSTICS
Rear Panel Connectors:
- 1 LNB Input (2F-type)
- 2 x Audio L/R (RCA)
- 1 x Video SIGNAL (RCA)
dont see HDMI on there....nor the USB connector it claims it has
How is it HD?
From it's listed specs...
Composite Video? Not even a HDMI port.
I would hate to see people waste $44.
Well if they were recorded with that box (which may be possible if you add a USB hard drive) but with those specs there is no way you can output live HD to the TV.
I got a hold of them the STB does have an hdmi 1.3 port.
As a suggestion
maybe we can create a $1 or $2 account so members can donate and SatGuy can get one box such like this one or others and have someone make a review??? If is worth then we will all going to know , if not them we only loose a buck or two.
carlospr43 said:
As a suggestion
I'll give $5.
Picking someone may get ?
But I have a feeling the software will be jacked. I wonder if it's just the demo board design with some patched more times they stop changing the rev # that any good software engineer would throw a fit over. Lol
Well his ebay listing seems have the correct specs. Take note of the SCART output option as I wonder if it comes with the adapter. Someone here reviewed a box shipped from China that had this connection. It could be a clone of it.
Features
High Definition MPEG4 AVC/H.264 HP@L4,MPEG-2 MP@HL/ML and MPEG-2/DVB S2 standard
Supports DiSEqC 1.0/1.2
0/22Khz Tone
Super fast Blind scan for easy installation
SCPC/MCPC Receivable from C/KU band satellite
3 Operation Modes ( Digital TV, Digital Radio, Favorite)
950-2150 Mhz Input Frequency
Video Resolution(HDMI): 1920X1080 (1080P)
ALI 3601 chipset for superior performance
Dolby surround sound decoder with Digital coaxial output
High performance EPG
PAL -NTSC auto -conversion
Aspect Ratio: Auto, 16:9 Pillar box, 4:3 Pan & Scan, 4:3 Letter Box.
Support USB PVR function for program recording
Latest software version and enhanced circuitry allow for Reception of even the weakest signals
Product Specifications:
TUNER
- Input Frequency : 950 to 2150 MHz
- Input Level : -65 to -25 dBm
- LNB Supply : 13 V / 18V / OFF , Max 400 mA
- Demodulation Type : QPSK
- Symbol Rate : 4 - < 45 MS/s
AUDIO /VIDEO PROCESSING
- Audio Standard : ISO/IEC 13818-3
- Audio Channel : Mute, Left, Right and Stereo
- Audio Decoding : MPEG-1 & MPEG-2,
- Video Standard : High Definition MPEG4 AVC/H.264 HP@L4,MPEG-2 MP@HL/ML and MPEG-2/DVB S2 standard
SO/IEC 13818-2,MPEG-2 MP@ML
- Aspect Ratio : 4:3
- Video Resolution : 720 x 576 ( PAL ),720 x 480 (NTSC)
- Video Format : 4:3
POWER SUPPLY - Type : Switching mode
- Input Voltage : 100-240V,50/60Hz
- Power consumption : 18W max
TV SCART(RGB/CVBS) , HDMI, SPDIF coaxial out plus Optional CVBS/YPBPR interface);
The company website and the Ebay listing both have a hodgepodge of specs based on a SD DVBS QPSK receiver. Why would someone go to the effort of multiple postings with completely incorrect information? Unless they don't understand the technology?
here is C/P I got from their Customer Services department
here's the hd receiver back, it does it all.
----- Original Message -----
To: 'www.oceansatellite.net'
Sent: Tuesday, September 18, 2012 6:03 PM
Subject: RE: Oceansat dvb-s2 HD HDMI FTA Receiver
Well, its not that you will make business with Puerto Rico. You can add what we ask in your site so other sponsors and colleagues FTA forums in the USA can clarify their confusions. A lot of us here in PR have families in USA so it will not be a problems for us to get the box from there using a USA address and a USA bank credit card.
Originally we heard from your box in some of our friends USA forums.
Regards,
De: www.oceansatellite.net [mailto:cs@oceansatellite.net]
Enviado el: Tuesday, September 18, 2012 5:47 PM
Para:
Asunto: Re: Oceansat dvb-s2 HD HDMI FTA Receiver
To many issues with fraud and chargebacks with Puerto Rico, so we do not serve your area.
To: cs@oceansatellite.net
Sent: Tuesday, September 18, 2012 5:43 PM
Subject: Oceansat dvb-s2 HD HDMI FTA Receiver
Hello
Congrats on your new HD DVB-S2 product. Can be possible to post a rear view image of the box?? There is confusion as to which connector may have. Also, a picture of the main menu look of the software will be of a great help. This is a great and affordable price product we may encourage members to get.
Regards and Again, Congratulations
Here is a pic of the back panel they emailed me:
Edit: Carlos beat me to the trigger.
So since the PS is in the unit no DC no UL.
another turbo hd dish.
Maybe I need a new dish for my setup?
