super dish and 61.5 | SatelliteGuys.US
super dish and 61.5
miecio
10
could anybody helpme with my problem? I do have super dish with german program on ch 725,726,and 727 and dp34 switch box everthink works fine.
Today installer came and put another dish 61.5 so I can have euronews on ch900
and he replaced DP34 for Dp 44 so after check switch I do have
121,119,110and61.5 and woila euronnews pops in but germab channels wanish
however some other 700 are present.Question is how to get them back.please help.
Grab your remote and put in the channel number you want to watch and then push "Menu"... then 6... 1...1... and look at the signal strength on the screen.... it should be over 60%...
There is a recommended order for hooking up the 4 coax lines to your DPP44 switch... I don't have the DPP44 manual with me right now... but I think 119 goes to port one.... 110 to port two... and your 61.5 to port 3 and your 121 to port 4...
Thank you very much I did follow you recomendations and everythink is the way
I wanted. super.
dishes pointing at both 61.5 and 129?
Dish Network on my computer monitor
