I hope someone can help.
I have installed a number of dishes. This one is giving me a headache. Any suggestions are greatly appreciated.
When I run a check switch...on this superdish install...I get a message "check connections"...I have tried moving the 2 connections on the DP34...I have re-done the cable between the 2 LNB's and the DP34....I have run a continuity check on that cable (both ends) both cables are fine. The 3rd LNB checks fine. The box sees that cable in any of the 3 F connectors on the DP34. Any suggestions?? Anyone have this same problem?? Many thanks in advance!!
