trojan67 SatelliteGuys Pro Original poster Sep 5, 2015 399 134 Jamaica Jul 31, 2020 #1 Anyone knows if the FSS lnb, on the Super dish works with 118 sat?
M Magic Static SatelliteGuys Master Lifetime Supporter Oct 12, 2010 7,498 4,853 Montana Jul 31, 2020 #2 No it won't ,FSS is linear 118 is circular Reactions: (((Garyd))) and TheKrell
trojan67 SatelliteGuys Pro Original poster Sep 5, 2015 399 134 Jamaica Jul 31, 2020 #3 Magic Static said: No it won't ,FSS is linear 118 is circular Click to expand... OK, thanks
(((Garyd))) Retired C-Band dealer Lifetime Supporter Sep 4, 2007 29,653 25,073 diamondsatellite@snet.net Jul 31, 2020 #4 trojan67 said: OK, thanks Click to expand... if you open it up and pull out the plate inside its no longer circular
M Magic Static SatelliteGuys Master Lifetime Supporter Oct 12, 2010 7,498 4,853 Montana Jul 31, 2020 #5 (((Garyd))) said: if you open it up and pull out the plate inside its no longer circular Click to expand... Think about what you just said LOL
trojan67 SatelliteGuys Pro Original poster Sep 5, 2015 399 134 Jamaica Jul 31, 2020 #6 (((Garyd))) said: if you open it up and pull out the plate inside its no longer circular Click to expand... Doesn't carry a plate
