Super DMA but wrong info in guide | SatelliteGuys.US
unoquatrouno
6
Is anyone else having the same problem, where the Super-DMA was rolled out and the guide display the wrong tv show or a local station gets over mapped with its affiliate from the other city? I tried to hide those channels and re-scan and I still have the same problem.
Any suggestions? :confused:
I am not sure whether it is the same problem, but I have channnels where they are not supposed to be.
eg. channel 301 which is ESPNHD will show another program (maybe HBO?).
I have this problem only on one receiver/TV. The other receiver/channel shows the correct channels.
Tried to switch receiver off but does not correct problem. Not sure how to rectify this.
I saw this under the section on the Motorola receiver.
This may be the problem.
"I am getting BravoHD+ instead of StarzHD on channels 261 and some other channels are messed up too"
When you tune to certain channels (204, 206, 226, 229, 261, 262, 301, 305, 522 and 523), the STB sends a signal to the LNB to switch polarity from "Right_Ve" to "Left_Horiz". If this fails, you end up getting a wrong channel. This problem can be caused by bad LNB, bad multiswitch, bad diplexer or by improper wiring. Request service from VOOM
List of TV Models with DVI Problems
Windows Media Center and Voom Local Listings?
