Superdish 105 Question | SatelliteGuys.US
Nick2498
9
I installed a superdish 105 for a friend. Im able to get 110 and 119 fine (signal strength 110-125) and can get the 105 sat at around 50-65. But the problem is, on sat 105 I can get the transponders from 23 down to 8 to lock fine, but transponder 7-1 I get a signal that jumps from 50-60 down to 0 then dissapers then comes back again a few seconds later but wont lock. Is there something I'm doing wrong here?
Thanks,
Nick
Can you please tell us the entire setup? This can help use "see" more and try to pin-point instead of you having to read 100 guesses.
1. Dish: Superdish
2. Receiver(s): ?
3. Switch(es): ?
4. Diplexer(s): ?
5. Cabling: ?
The dish is a superdish 105. The ird is a 301-013 single w/ vid mod running Rom10. The switch is the one supplied DP34. And the cable is RG6
what locals are you trying to pick up? They would be on one transponder on 105, so the rest are irrelevant.
just a reminder...we don't condone theft of service here :)
TuxCoder said:
By "w/ vid mod", what kind of modification do you mean has been done to the receiver?
Never mind his receiver has been hacked. I think this thread will be closed.
on that pleasant note, and reading this a little more...CLOSED
we do not allow hack talk here
n0 beat me to it :)
Problem with remote #2 on 522
Change of Plans?
