SuperDish 121 Repoint Kit - Available ? | SatelliteGuys.US
SmityWhity
1,246
Denver, CO
All you have to do is remove the Superdish LNBF assembly, put the 500+ LNB in its place, mark the hole, drill it, put the 500+ feedhorn in place with one of the bolts you took out from the superdish, adjust the azimuth just a hair and viola not kit needed.
Dave Nye suggested that a year ago "frankenstein 1000+". I've used it many, many times with no ill effect.
129 on 1000+
MOJODH should be next for a new HD channel
