Superdish/OTA combined | SatelliteGuys.US
jjnemoiii
234
I have a superdish, running through a switch on the dish. Can I use a diplexer to add my local hd ota signal to the same cable headed to my 811 receiver? For what it is worth, i am only using two of the three lnb's, the third on the outside I took off for portable dish. Ok, as I have no movie channels, and don't use ppv. I really do not want to run a second cable down to the receiver. is there a way around this?
I forgot to mention this earlier, but I brought this up because when the superdish was installed, installer unhooked FM antenna that was running with it, said something about switch behind dish or amount of power coming up line as to why you cant add the signal like I did with 18" dish. Of course, he also took ground wire, stripped off 6" of insulation, and wrapped it around painted mounting bracket through a hole in it. When I asked him about it, he replied, no, that is just fine the way it is! ( I fixed it right after he left).
Thank You for your help!!
Where is the Bird?
Missing any programming from 61.5 or 121?
