I MUST disagree, and point you to the SuperDish installation manual.
The final DP34 setup should ALWAYS, without exception, be 119=1, 110=2, and FSS=3.
Also, Dimmy, a SuperDish is NOT how you should be starting to learn multi-sat installs. :yikes
Thse problems you're seeing are more to do with technique and (lack of) experience. It'll get better.
Yes, it can be a good idea to bypass the switch and lock in 119 directly to start off.
As for the Dish 500, properly set, if you have 119, you should ALSO have 110. IF you are seeing 119 in column TWO f the switch matrix, you're 9 degrees off.
Remember - until you have a REAL good handle on the angles, you MUST ensure that mast is always dead plumb or you're gonna drive yourself crazy.
Finally, 110 IS there for a reason - a lot of channels.
