superdish | SatelliteGuys.US
superdish
You may be able to make or buy an adaptor which would allow you to mount the dish onto a 2 3/8" pole/mount which are easier to find than the 2" pole. An adaptor could be made to make it fit on the 1 5/8" pole (same as what the Dish300 or Dish500 uses) but may not be enough support for the dish. You could also use a U-Bolt clamp to mount it to a pole (preferrably a bigger pole or one that may already exist where there is a clear line of sight to the satellite).
