Supported EHD Types for Hopper 3 | SatelliteGuys.US
medvyed
19
10
Acworth, GA
What types of hard drives are supported as EHDs for the Hopper 3? Do the drives have to have their own power supply, or can they be USB-powered? What is the maximum supported drive capacity?
There are certain requirements for a Hard Drive to become compatible with the receivers. You can always go online to myDISH.com and click on "Order From Store" to buy one.
You can also check out this to see those requirements: Request Rejected It will be under "Compatible External Hard Drives" at the bottom of the page.
Q3’19 SEC posting?
LOCAST
