SV2000 TV / VCR / DVD Combo & 40.0 Remote | SatelliteGuys.US
aaronwt6
367
2
SE Georgia
Has anyone had any luck getting the new Hopper remote or possibly a 32.0 for the 922 to control one of these TVs? I put a system in yesterday for someone and couldn't figure this one out. No SV2000 listed in the Hopper's remote setup screen either.
This is tricky because the DVD and VCR portions use different codes. So they must be treated as 2, possibly 3 separate devices. The DVD side is compatible with DVD code 0675 (20675), and the VCR side with VCR code 1593 (21593). Power is part of the VCR codes.
As with any remote that uses UEI codes, most can be found in the JP1 database or any one-for-all database like you'd find at one-for-all or cable company support sites. Unfortunately, I couldn't find the codes for the TV portion, so those would have to be found with a code search or learned.
Thanks. That's pretty much what I figured. I'll try to stop by the customer's house soon when I'm in the area and try it. It would be a first for me on that remote.
Local's
Topeka KTMJ HD
