sw64 switch dish 118.7 | SatelliteGuys.US
No that will not work. If you have legacy recievers you need to use a dp 34 with dp adaptors or you can get a dpp44.
DPP 44 Switch does not work will all Legacy STBs. Call dish and get an upgraded STB. If you are being migrated from 61.5 or 148 to the 118.7 the upgrade will be free if you get the Warranty
Dish Adds 30 HD Channels in Hawaii & Alaska
522 DVR no power
