Sw64 | SatelliteGuys.US
Sw64
lowcash
2
I was planning on upgrading my sw21 switch to sw64. I'm trying to find out if I need to buy the power supply and inserter also? Can i just hook up the sw64 switch??
Yes. You do need these; however, they are included with the switch if you buy it new. The inserter must be on output #1. Make sure you install it correctly. Mine works just fine.
--Doug
DVR 522 installation problem with legacy equipment
Anybody else notice sound sync issues on TNTHD
