Swapping Receivers | SatelliteGuys.US
Swapping Receivers
golem
30
Southern California
Currently I have an 811 with Dish network hd subscription and would like to replace it with a VIP222, probalby purchasing one off eBay or something. How exactly would I go about activating the receiver? I can't just swap the cards? Do I have to call Dish tech support to get them to do it?
Buy it (a VIP 211) from Dishstore.net It will cost you $234.00 and you won't get screwed on Ebay. Then just hook it up and call Dish to swap them. They will ask you for the numbers off the receivers.
$1 freeze
HD channel authorization SLOWER than SD channels on 622?
