Sweet Application | SatelliteGuys.US
Sweet Application
Freekmastr
16
I found this website a while back while hooking up my FTA system. I know that number and angles and skew and stuff can be difficult for newer folks. This website allows you to pick a town near you or click on a map to choose your location. Then you pick the satellite you want to try to aim for. Click on a final button and it gives you all your angles and even had small pictures with the numbers. If you cant figure out numbers, just do what the pictures say to do. I liked it, helped alot, thought Id share.
http://www.igp.net/Antenna_Alignment/Index.php
what sats can I pick up on fta
coolsat ...how to add a new satellite?
