SWiM question | SatelliteGuys.US
SWiM question
crazyglue23
2
Florida
I am new to this board. I have a hr22 receiver and SWiM at home. My question is: can I use the hr22 reciever with my non SWiM LNB dish in my RV? I used to be able to before I upgraded the rest of the house to the whole home dvr. The reciever is the same one I had before the house got SWiM. Thanks in advance for your response.
Yes, you would need 2 cables from the dish if you want the dual tuner function, plus you will need a b-band converter installed in each tuner, plus you will re do the satellite setup settings, and chose single or dual tuner, and multi switch, instead of SWM
Direct or Dish, can someone hook me up
Direct TV Dish Mast Size in Central Texas
