Switch Box | SatelliteGuys.US
Switch Box
tim1970
16
Is there an easy (and cheap) way to expand the 2 cables I have in my living room into 3? Outside of my house I am already using a 3-8 converter, and all my 8 lines are being used. I would like to be able to have 2 lines for my non-hd tivo, and an additional line for my HD Box. I would even consider some type of A/B switch box, if that is possible.
Tim
A 3X8 won't support HDTV you can only get the 101 satellite through it. If you are satisfied with 101 only programming you should be able to take the two cables from the 3X8 and run into a 3X4 that will give you 4 outputs 2 for the TiVo and 2 for other receivers.
H10 Lockup problem
Starz Channels
