Switch help installing 211k HD | SatelliteGuys.US
fcravioto
21
Mexico
Hi I have 3 antennas pointing each at 119w 110w and 61.5w.
I have eagle aspen lnb on each antenna.
I will install a vip 211k receiver and dont know how to install it.
What type of switch do i need and what type o diagram.
Help is welcome.
thanks
Help is welcome.
thanks
Eagle Aspen says Directv LNB or LEGACY the only switch you can use is a SW-64
Seeing 61.5 won't get all the HD you need to add 72 or switch to 129. Unless you have LOS problems a 1000.4 Eastern Arc or a 1000.2 Western Arc should be in your future.
If you look closely, the OP is located in Mexico. Satellite beam coverage is relatively (and intentionally) weak with the new satellites.
signal strength
DISH Network Reports Third Quarter 2010 Financial Results
