Switch Options for DPP Twin LNBF | SatelliteGuys.US
JWC
82
I used the Dish mover service and found out the hard way that they only pay for the basic installation. They wanted $100 to install a second dish to cover the 61.5 spot (even though I had coverage for all three satellites at my old location) so I just swallowed hard and said I would move my old D300 dish myself and plug it into the "input" connector on the DPP twin. I know I need to get a different LNB because my old set up was legacy LNBs. Since I "only" had two receivers (811 and 6000), they simply connected each to a set of 4 cables I had run for expansion using a DP34 or DPP44 architecture. This is history and I am trying to understand/accept their business decision.
What I want to do is to accomplish my original architecture with DP34 switches instead of DP44. I have 9 drops in the house and intended to move a new receiver/Tv on a cart to where I wanted to use the 3rd set. Since I ran 4 runs (from the dish location(s) to a central space in my attic and the 9 drops from wall outlets to the same location, I am trying to see if it is possible to use DP34s instead of DPP44 (because of cost). I am getting conflicting information as to whether the DPP twin is compatible with the DP34 and if not I can figure out the economics of changing the DPP twin with a DP twin (or other type). What do you recommend. I don't think I will be needing 4 satellites and that three will do. I miss some of the channels on the 61.5 shot and would simply redirect that satellite to 129 or wherever they put the HD expansion chanells. What LNB should I get for the D300?...a DPP, DP single, DP dual that makes a practical expansion at a reasonable up front cost.
Thanks, Im not cheap or frugle...only trying to avoid a high up front cost...if indeed I am not making a mistake with limiting myself to three satellites. I am mostly interested in HD channel expansion options...including future locals in HD.
if you have any local channels at the 61.5 slot, dish HAS to install that as a Must Carry dish, for FREE, no installation charges or whatever.... FCC says so
You can use a DP34 switch with a DDP Twin by connecting the 119 and 110 to the 1 and 2 ports on your switch and it will act as a DP Twin this will disable the input port on the DPP Twin and you will run one line from your 61.5 DP Dual to port 3 on the DP34 switch. Or you can just run a line from 61.5 DP Dual to the input on you DPP Twin and not use the 34 switch.
How to delete and edit Dish Pass entrys on 942
311 Transponder Prolem
