Switch position question | SatelliteGuys.US
TC_Lauderdale
103
Plantation, Florida
Sorry if this is a repeat question, but I did do some thread searching before I posted this...
Maybe PSB or Iceberg can resolve a ongoing conversation my co-worker and I are involved in? What is the proper position of a 4*1 DiSEqC switch when using a motor? Is is before the LNB's or before the motor or does it matter? :confused:
Cable from receiver to motor, from motor to switch, from switch to the LNB's
(Thats when you are using two LNBF on the same dish (KU/DBS)
it can be used in either spot. I use to go receiver.......4x1 switch.....motor.....LNB
but that can burn a switch ouot pretty quick. Now I put it between the motor and the LNB's......receiver......motor.....switch
The LNB's that dont need the motor, leave the motor function off :)
Before any of these, make sure you turn/switch off the receiver. A MUST !!!
Equity did a call in show last night
FTA Programming
