Switching back to D - some questions | SatelliteGuys.US
mbereg
2
Hello all,
We switched from D to Cablevision (LI) about 4 years ago when they had a lot more HD programming.
Fed up with Cablevision's increased prices for decreased services. The Academy Awards fiasco was the final straw.
Our original install has a round dish with RG6 cable to three rooms. We also have an RCA D6520 multiswitch set up where the cable enters the house for distribution. (That multiswitch has LNB-A 17/18V and LNB-B 13/14V inputs and 4 outputs.)
We had hoped to switch to get a Tivo HD receiver (We LOVE Tivo) but that doesn't seem like it's happening anytime soon.
Am I correct that the installer would give us a newer type of dish? Is our current cabling still ok for HD standards? Will we still need the multiswitch or is a different one required?
Thanks for any input.:)
Apc
Welcome.....
You will get a new dish. The cables will probably be fine. The multi-switch is trash. DVR's require two cables to each room, unless you get a SWM dish. A lot of areas of the country are using SWM on all new installs. Some areas have a minimum tuner requirement. I wouldn't worry about it much. DirecTV should provide everything you need as part of your free basic install.
Good luck, and welcome back!
cricket ticket
Just curious
