Switching from Sirius to XM | SatelliteGuys.US
jcoppola
233
38
Charleston, SC
I have Sirius with best of XM on a portable unit in a work vehicle. I am about to get a new work vehicle that has XM built in. Is it a simple process of calling up and deactivating the Sirius unit and transferring my subcription to XM?
Yes, it is that simple. However if you are under any promotion. The promotion will not transfer.
Here is what you do. (assuming XM is built into the vehicle) when you call, tell them it is a new vehicle (to you) and you will get three free months.
You may end up paying more, if the programming you want is on Sirius as XM does not have the same A'la Carte
XM Roady XT FM Transmitting Problems
Antenna Not Detected
