satjay, I thought D* was coming out with a multiroom DVR this year
I am with E* right now, but if D* came out with a multiroom DVR, I would be on board in a minute
What they're supposed to come out with is Multi Room Viewing, not a multiroom DVR. What MRV will allow is to view something recorded on a HD DVR via ethernet connection (wired/wireless/powerline) on another set top box. The advantage that this has, at this time, is that you can view recorded HD material in HD on the other STB in HD, not SD via coax like E*'s current solution.
For more information on what's happening in this area check out the Cutting Edge section of this web site.
Being able to have Multi Room Viewing in HD is a good option. That is what UVERSE is advertising. A major problem with UVERSE is you can only have a maximum of 2 HD streams
Ok, I'm tired and have a lot on my mind. What's SMV stand for again? And that will do what for me? Thanks again, a very long day for me.
Jeff
A thought for you. In our case, we have TV2 on one of our 722s in the bedroom. It's just my wife and I and we NEVER watch TV1 and 2 at the same time. So instead of ordering a seperate SD receiver, I going to use an RF modulator. The HRXX remotes are RF capable, so when she is in the bedroom, she will have control. Plus, she'll be able to watch recordings. I'm getting two HRXXs. She'll be able to use one of the remotes in the bedroom since I use a Harmony in our main room. So for us, things will remain "normal". Your family's viewing habits may not work for such a set-up.
To control the DVR from another room it has to be in RF mode, but the Harmony will only do IR.
Should not matter with SD channels, should it?Also, you will probably want to switch the aspect ratio from 16:9 to 4:3 when using a RF modulator to feed a SD set in another room.
My DVRs are all hooked up to HD and SD TVs and I never switch.
Harmony in same room as receiver.
Not a problem. Harmony with another receiver not being shared.IR is turned OFF when RF is on. In other words, no Harmony remote + a second RF remote. I ran into that when I set mine up.
Limited time offer
