SWM Question | SatelliteGuys.US
SWM Question
drwindmill
55
Will the SWM 5 LNB work on the older heavy original 5 LNB dish? Or only the slimline?
Actually, you may be able to make it work, but you might have to modify the mount for the LNB and the dish reflector is not exact for that LNB, so you may have lower signals.
Also consdier the slimline 3 LNB (99/101/103 only) if you don't need 119 for SD locals.
What is good signal? (by the numbers)
Phone Line Needed?
