SWM set up questions for recording and b band converters... | SatelliteGuys.US
curtishd
181
I'm helping a friend out changing his current set up from a regular SL3 to a SL3 SWM set up. He lives in a condo that is prewired but has only one cable to each receiver so currently when he records a show he can't change the channel or the recording will stop. My question is will he be able to record one show and channel the channel with just the one cable coming into the receiver even if the does not get the Whole Home DVR set up/ monthly fee? Also he has HR22's so does he need the b band converter once he has the SWM?Also my understanding all I need is the SL3 SMW, power inserter and the splitter right?
yes be sure to rerun setup. no b bands needed on SWM and yes power inserter and SWM splitter.
make sure in the sat setup it says tuner dual
Whole home is not needed
correct. But if he is in a condo there is probably a community dish on the roof and a PI already in the line somewhere (maybe the room where the cables are hooked up for the subs)
family pack
HR24 Drive About to Go??
