Symphonic TV remote code | SatelliteGuys.US
techno935
1,048
Pompano Beach, FL
I have the RC23 DirecTV remote with a D11 DirecTV receiver set up for my sister.
Tried both codes for the Symphonic brand TV and both don't work. Any idea on how to find out if there is a possible working code for that brand? Would appreciate any help. Thanks.
try doing the search,
put it in tv mode
enter 991 let it blink
enter 1 let it blink
then hit channel up til tv goes off
once tv goes off hit select and the code is locked
if ur tv has av inputs, do the same thing except enter 960 and select.
then try using the tv input button to see if it works.
this should work if your tv isnt a combo (ie tv/vcr, tv/dvd), if so then you should use both tv codes and other component codes in av mode and av1 mode, i suggest looking on directv.com and find the manual for that specific remote.
D* Local HD Harrisburg, PA - screw up
HD locals
