System Info Status question | SatelliteGuys.US
Videomax
55
Hi,
I just had to activate a new receiver because my old one broke. Activation seemed to go well and channel are fine, but when I do a system info check, I get the message "Check "Details" for LNB!" and when I check details, I get the message: "LNB Drift Detected..."
What does this mean and should I be concerned?
Thanks,
Dave
But LNB drift is compensated for to some degree in current receivers. It could stay like that for years. I don't think Dish is going to be interested in repair unless it's gotten so bad as to interrupt your viewing.
You do pay the $5.99 DHPP, don't you? If not, you could be hit for the full repair cost.
I do pay the $5.99 fee.
In people's opinion, is it something I should just wait until something goes wrong before I have it checked out, or should I just go ahead and have it checked out right away?
So far, everything seems to be fine.
What exactly does LNB drift mean and how can it affect my viewing?
<skip>
Using Search for "LNB Drift"
http://www.satelliteguys.us/dish-ne...9-lnb-drift-detected.html?highlight=lnb+drift
http://www.satelliteguys.us/dish-network-forum/137578-lnb-drift-service.html?highlight=lnb+drift
http://www.satelliteguys.us/dish-ne...ny-stop-gap-solution.html?highlight=lnb+drift
http://www.satelliteguys.us/dish-ne...-stb-health-lite-wth.html?highlight=lnb+drift
http://www.satelliteguys.us/dish-ne...nb-118-indicates-red.html?highlight=lnb+drift
http://www.satelliteguys.us/dish-ne...8-lnb-drift-detected.html?highlight=lnb+drift
http://www.satelliteguys.us/dish-network-forum/120516-lnb-drift-detected.html?highlight=lnb+drift
http://www.satelliteguys.us/dish-ne.../112383-lnb-problems.html?highlight=lnb+drift
http://www.satelliteguys.us/dish-ne...drift-detected-110-a.html?highlight=lnb+drift
http://www.satelliteguys.us/dish-ne...-drift-after-i-moved.html?highlight=lnb+drift
http://www.satelliteguys.us/dish-ne...ing-signal-lnb-drift.html?highlight=lnb+drift
http://www.satelliteguys.us/dish-ne...pport-answer-correct.html?highlight=lnb+drift
http://www.satelliteguys.us/dish-network-forum/93117-lnb-drift-detected.html?highlight=lnb+drift
http://www.satelliteguys.us/dish-ne...s/89627-lnb-drifting.html?highlight=lnb+drift
http://www.satelliteguys.us/dish-ne...ift-detected-problem.html?highlight=lnb+drift
http://www.satelliteguys.us/dish-network-forum/102237-lnb-drift.html?highlight=lnb+drift
and a few more :D
You can save your self the $5.99 DHPP fee and cancel it and when you need maintenance for which you have to pay you can reactivate the DHPP and you will be good to go.
I had a problem with my switch and the CSR said I should order DHPP and it would cover my problem even though she knew that I already had a problem.
This reduced my bill from $99.00 to $29.00
How did removing a $5.99 fee save you $70
Ciel-2 Launch Thread - Launch Date Set
