I have a VIP222 dish HD with software L503. The dang thing keeps rebooting a lot of the time when remote 1 is using the program guide. They have replaced the receiver and LNB, with no help. What next? Please help wife is irate!!!
He's got a 222 not a 722.... To the OP, is your 222 well ventilated. Open air all the way around top and bottom?
It should go to the acquiring signal screen when it resets, followed by the EPG download. Have you tried plugging the receiver into another electrical outlet in the home? Also, bypass any power strips or surge protectors you may be using.
722's are notorious for repeated boots. Send for another one if you are positive there is no problems with the cabling or connections.
cwchase10 said:Just got this from a Dish rep. on another board.
"We are aware of this issue and a software update is required. The software you mentioned is the current version for that receiver. I will check with our engineers when this update is available. I hope this helps."
Software issue? Is everyone with a VIP222 dish HD receiver having this trouble?
Limited time offer
