T5 Problems!! Can't scan all TP's | SatelliteGuys.US
xtra
55
Halifax,NC
I can't seem to scan all the transponders on T5, I know there are alot but I scanned and only ended up with about 44 channels instead of over 100. Are some of the transponders down?
MrMylesG said:
I noticed the same thing. Half of the transponders have no signal at all.
Check the coax & coax connectors .
Are you using a LNB or LNBF ?
Check the skew ?
Wyr
All my other linear sats are fine with strong signal. I have a 1.0 meter dish with a Invacom QPH-031 LNB. SG2100 motor.
did you try to nudge the dish a little bit?
IA5 seems to be the land of crazy signal strengths...some are at 99, some at 30...bump it onoe notch and the 30 turns to 50
Dishnetwork attena Question??????
Ready to start
