Tailgate kit question. | SatelliteGuys.US
AllStarGuard
23
Central Illinois
My current setup at home is as follows:
HR22-100 and H21-200 with SWM
I would like to bring my HD receiver with me in my camper for football games this fall. If I purchase a tailgate kit from Sadoun (
TGKit-3) do I need to also purchase power inserter between the dish and H21-200 receiver? I have one between my HD-DVR and the multiswitch now.
My goal is to have the gear ready in the camper and just grab the receiver and go.
With the SWM installed at home I don't believe that your receivers use the B band converter in that set-up. However, if your "travel" dish is not SWM, I believe you will need to use the converters on your travel box if your travel dish is HD capable.
With that kit you don't have to get the power inserter. Your home setup is the SWM setup which requires that power inserter you see behind your HDDVR. The TGkit-3 setup from saduon is a non-SWM setup which does not require a power inserter.
When will a new sat go up?
Am I going to be able to get direcTV? (Pics)
