TBN | SatelliteGuys.US
TBN
corunnaflyer
27
ontario
Why do I get virtually no quality for TBN? A friend has the same problem, he has Glorystar receiver and I have Viewsat. 4043 and 4038 on Viewsat.
This could occur if you optimized the Signal Quality on 11842 instead of balancing on three transponders: 11842, 12115 and 12152.
For GloryStar receivers, balance on channels 106, 113 and 901.
I don't know what you mean by balance. I am using Viewsat ultra not Glorystar receiver.
take an average of a few transponders and aim the dish that way. 97W is kinda wacky that a couple transponders seem to be "off centre". I know on my 30" dish if I peak on the 11842 transponder (that has 3ABN, LLBN and other Adventist channels) I lose signal on a different transponder. If I peak on that other TP I get real low quality on 3ABN. I learned to try 3 different transponders and find the happy medium
corunnaflyer said:
Haven't touched dish and TBN came back on its own?
I would investigate the integrity of the dish, mounting, coax cable and connections. There has been no changed in the signal quality readings of the 12177 transponder.
Glorystar Updates
Glorystar Always says there is a new version available.
