tech question | SatelliteGuys.US
tech question
harbinsdeck
grenada,ms
If i live in olive branch mississippi and want to have another 1000.4 hd system in my grenada ms home, will i be able to get the same channels i already have. i don't want a new account. i have a x-tra rec in a bedroom i want to use when we go to my house in grenada
Ask DISH I think they might call that account stacking and require a separate account.
Here are the two options:
1. If you own the second home and it is a vacation home, E* will allow you to switch service back and forth between the two locations. There is only one service active at a time. The advantage to this is that if your locals change as you move to the other location you will get the ones you need. You can also do a Dishmover and have them do the install if you want.
2. The second option is to install your own dish and drag a receiver back and forth. Technically as mentioned above, this is likely viewed as account stacking and a violation of your agreement with E*. People do this of course, but it's not exactly kosher if there are people left at the original location also getting service. If you leave the extra receiver at the second location and get an audit, you'll be caught dead.
Helps to Raise Hell
Will my Old ConUS Local Channels stay on Spotbeams now?
