Telstar 12 set up on Pansat 2500 | SatelliteGuys.US
lagers20051
I need help!!
I'm trying to get the greek station ANT1 on Telstar 12 dish from Toronto and can't seem to get any kind of signal on the reciever. I don't know if my dish is too small, the bird is too low on the horizon, have the wrong lnb, or just a bad setup. Here's what I have/know:
Equipment: I've got a 33" in dish and a pansat 2500a. The LNB says "Microelectronics Technology, AP8-XT2, 10.7-12.75 GHz, Universal Golden Single 40mm 0.6db. Is this the right LNB?
I got the azimuth off a satellite site at 108.32 at elevation 9.76 and I've played with the skew...but nothing
Lyngsat shows the following for this satellite:
Freq: 11804 tp 24
SR 3300
ON THE PANSAT:
I've checked T12 but I'm not sure of the parameters.
LNB TYPE: There are several options here...but I don't know which is the correct one...and Yes...I've tried them all.
1) Standard 10750
2) Single 10750(v)/10750(h)
3) Universal 1 9750/10600
4) Universal 2 9750/10750
5) Single SL 5150/5750
6) Single SH 5150/5750
22KHz is OFF
DisEQc is OFF
SKEW 45
TP...I added one ... 11804H 3.3 which I think i did correctly to match the lyngsat info for ANT 1
What's the correct setup and what am i missing here?
Hello and welcome to the SatelliteGuys.US FTA forum :wave
I would try to set up your system to an easy to find satellite first as IA-12 is really at the fringe of reception and the dish elevation is so low it will be a problem. You can always come back to this satellite and try again, but I feel you will need a bigger dish and a lower noise LNBF.
Universal 1 is the correct LNBF setting.
http://www.lyngsat.com/tracker/t12.html
Latitude 43° 0.000'N Longitude 79° 0.000'W
Here are the angles for some other satellites for now.
Sat Name Sat Lng Az(t) Az(m) El Skew
*** All Satellites 61W - 160W ***
EchoStar 3 61.5W 155.2 167.0 37.3 -17.9
Rainbow 1 61.5W 155.2 167.0 37.3 -17.9
Brasilsat A2 (incl. 5.8 deg) 63.0W 157.2 169.0 37.8 -16.5
Brasilsat B2 65.0W 159.9 171.7 38.4 -14.5
Brasilsat B1 70.0W 166.9 178.7 39.6 -9.5
Nahuel 1 71.8W 169.5 181.3 39.8 -7.7
AMC 6 72.0W 169.8 181.6 39.9 -7.4
Galaxy 12 74.0W 172.7 184.5 40.1 -5.3
SBS 6 74.0W 172.7 184.5 40.1 -5.3
GOES 12 75.0W 174.1 185.9 40.2 -4.3
AMC 5 79.0W 180.0 191.8 40.4 0.0 Your True South Satellite :yes
DirecTV 3 81.8W 184.1 195.9 40.3 3.0
Nimiq 2 82.0W 184.4 196.2 40.3 3.2
Brasilsat B3 84.0W 187.3 199.1 40.1 5.3
XM Roll 85.0W 188.8 200.5 40.0 6.4
AMC 9 85.0W 188.8 200.5 40.0 6.4
AMC 3 87.0W 191.6 203.4 39.7 8.5
Galaxy 9 91.0W 197.3 209.1 38.9 12.6
Galaxy 11 91.0W 197.3 209.1 38.9 12.6
Nimiq 1 91.0W 197.3 209.1 38.9 12.6
Brasilsat B4 92.0W 198.7 210.5 38.7 13.6
Telstar 6 93.0W 200.1 211.9 38.4 14.5
Galaxy 8I (incl. 1.0 deg) 95.0W 202.8 214.6 37.8 16.5
Galaxy 3C 95.0W 202.8 214.6 37.8 16.5
Telstar 5 97.0W 205.5 217.2 37.1 18.3
Inmarsat 2 f2 (incl. 1.7 deg) 98.0W 206.8 218.6 36.8 19.2
Galaxy 4R 99.0W 208.1 219.9 36.4 20.1
DirecTV 2 100.8W 210.4 222.2 35.7 21.7
DirecTV 1R 100.8W 210.4 222.2 35.7 21.7
AMC 4 101.0W 210.6 222.4 35.6 21.9
DirecTV 1 101.0W 210.6 222.4 35.6 21.9
AMSC 1 101.1W 210.8 222.5 35.6 22.0
DirecTV 4S 101.2W 210.9 222.7 35.6 22.1
AMC 1 103.0W 213.1 224.9 34.8 23.6
Solidaridad 1 (incl. 2.8 deg) 103.5W 213.8 225.5 34.6 24.0
AMC 2 105.0W 215.6 227.3 33.9 25.2
G-Star 3 (incl. 11.5 deg) 105.0W 215.6 227.3 33.9 25.2
G-Star 1 (incl. 6.0 deg) 105.0W 215.6 227.3 33.9 25.2
MSAT 1 106.5W 217.4 229.1 33.2 26.3
Anik F1 107.3W 218.3 230.1 32.8 26.9
Anik E1 109.2W 220.5 232.2 31.8 28.3
DirecTV 6 109.8W 221.2 232.9 31.5 28.8
EchoStar 6 110.0W 221.4 233.2 31.4 28.9
EchoStar 8 110.0W 221.4 233.2 31.4 28.9
Anik E2R 111.1W 222.6 234.4 30.8 29.7
Solidaridad 2 113.0W 224.7 236.5 29.8 30.9
Morelos 2 (incl. 4.4 deg) 114.9W 226.7 238.5 28.7 32.2
XM Rock 115.0W 226.8 238.6 28.6 32.2
SatMex 5 116.8W 228.7 240.4 27.6 33.3
Anik E2 118.7W 230.6 242.4 26.5 34.4
DirecTV 5 119.0W 230.9 242.7 26.3 34.6
EchoStar 7 119.0W 230.9 242.7 26.3 34.6
EchoStar 5 119.0W 230.9 242.7 26.3 34.6
EchoStar 9/Telstar 13 121.0W 232.9 244.6 25.0 35.7
Galaxy 10R 123.0W 234.8 246.5 23.8 36.7
Galaxy 5 125.0W 236.6 248.4 22.5 37.6
Galaxy 12 125.0W 236.6 248.4 22.5 37.6
Galaxy 13 127.0W 238.4 250.2 21.2 38.6
Telstar 7 129.0W 240.2 252.0 19.9 39.4
Satcom C3 131.0W 241.9 253.7 18.5 40.2
Galaxy 1R 133.0W 243.6 255.4 17.1 40.9
Satcom C4 135.0W 245.3 257.1 15.8 41.6
GOES 10 135.5W 245.7 257.5 15.4 41.8
AMC 7 137.0W 246.9 258.7 14.4 42.3
AMC 8 139.0W 248.5 260.3 13.0 42.9
Inmarsat 2 f3 (incl. 1.9 deg) 142.0W 250.8 262.6 10.8 43.7
EchoStar 1 148.0W 255.3 267.1 6.6 45.0
EchoStar 2 148.0W 255.3 267.1 6.6 45.0
TDRS 9 (incl. 7.4 deg) 151.0W 257.5 269.3 4.4 45.6
TDRS 10 (incl. 6.2 deg) 151.0W 257.5 269.3 4.4 45.6
EchoStar 4 157.0W 261.8 273.5 0.0 46.4
Satellite Finder is (c) Copyright 2004, P. Lutus
PBS etc on AMC3 w/ Twinhan 102g
I got legs!!!
