Tennis channel HD logo? | SatelliteGuys.US
trellaine
232
Vancouver
I am not sure if this issue has to do with my TV or ? but when tuned into Tennischannel HD the logo on the top right is cut-off between the Hand the D. I can see the Tennis fine.
Is this a TV issue? broadcaster? directv ?
It looks fine here, I've got about an inch of viewing past the HD portion, I would look to see what your current settings are on your box as well as your TV.
Sounds like it might be Cropped
Display area
Hey you encouraged me with your remarks. I checked the settings on my SonyXBR and I had the "display area" set to -2 so it moves the display. I quickly switched back to 0 or noramal and the HD logo is now where it should be. Hopefully it will be fine with all the other HD channels. :)
So it was an "Over Scan" issue ... glad you got it figured out :up
771 Driving me nuts
DirecTV Slimline 5-LNB Install
