Terk S26 dish and Spaun Multiswitch? | SatelliteGuys.US
gopherhockey
3
In my attempt to get HDTV into my home, I purchased the Terk S26 triple-lnb dish. It has s 4-way multiswitch built in.
This is not enough to distribute to all my receivers... so I have the need for a separate multiswitch. I'd like to be able to run to 8 receivers doing dual-tuner, so I'm looking at switches that can do up to 16 like the Spaun SMS51602NF model.
Does anyone know if this model would work with this dish? My concern is how the 4-way multiswitch on the dish will talk to the 4 inputs on the spaun..
The spaun is quite expensive so I want to be certain it will work right in this combination.
Thanks...
Get 2 5x8 Multiswitches and 4 Dual Power Passing Splitters, Line 1 from dish into one of the splitters, run 1 line to the input on one of the MS and the other to the same input on the other MS. Enjoy:D
WTT
daily loss of picture
What signal meter works with Terk S26 dish?
