Terk TV44 antenna with Swim PI-21 | SatelliteGuys.US
brequi
14
Reedsburg, WI
Is it possible to use a Terk TV44 antenna with the Swim PI-21 system? If yes, how do I install it? If not, will the TERK TV44 work on its own with a separate cable ran from it?
OTA with a SWM system is a big problem. You'll be better off running a dedicated line.
BTW, I haven't heard good reports about Terk antennas. Of course, this depends on how close you are to the towers.
how long would you wait
Dish Cover
