If I have my signal split after the receiver to addition wall plates should I use these termination end caps? Will they help the signal on the plate that I am using?
charper1 said:You may not notice any signal improvements with your eyes, but my experience is to always cap unused ends, where ever they might be; inside, on the switch, or at the dish. As I read it a while back:
The 75-Ohm termination cap provides proper termination for unused F-Type switch ports and Wall Outlet connectors. The termination cap
is used to maintain 75-Ohm impedance on unused outlets, CATV splitters, and
other equipment. The termination cap simply screws onto an F-Type connector
that is not in use. Without proper termination, unused ports and cables can
adversely affect signal quality and level. This problem is of particular importance
with digital CATV, Satellite and HDTV signals, and is frequently a source for
catastrophic system failures.
Limited time offer
