test patterns? | SatelliteGuys.US
test patterns?
neftv
199
PA USA
Does Dish have or ever have test patterns 4:3 or 16:9 to help people set up to there service? Just wondering about that it would just be like 3 or 4 slides needed.
no, but if you have the HD service from Dish,
HD net has test patterns.
The next is comming up on Sun morning.
Check your listings for times, or search for HD-Net test patterns
How do you use the HD Net test pattern. What do you look for for Black levels? Should you see all numbers? Whats the best way to set contrast and sharpness using this test pattern?
Crazy 322 Receiver
new install and local channels
