The 722K OTA Bug | SatelliteGuys.US
The 722K OTA Bug
cditty
1,293
35
Northeast Louisiana
So, I started getting tons of satellite signal lost indicators and of course, I suspected the OTA tuner losing signal... With springtime and the leaves, my multipath characteristics have changed and I now have a certain station causing me trouble.
My quick fix was to delete that channel from the tuner. I guess I'll be redesigning my OTA installation.
I wish Dish would fix this bug. It is so annoying.
... and I now have a certain station causing me trouble.
What bug? :confused:
Just cause it does not happen to you does not mean there is no bug. I have this issue also and it is a known bug that if u have a bad ota signal it will knock u out of sat too.
+1
I've had it happen on both my 622 and 722 (NON K). If/when it happens it'll even mess up your ability to view recorded programming.
Ed
Well, I have had no trouble after deleting the offending channel.
I think I may leave it out and not worry about moving the antenna. It's NBC and they suck right now anyway.
It seems to me that if I tune to my most stable OTA channel then switch to a sat. ch. it works fine. It is when my last viewed OTA channel is a weak signal and dropping out, that I have the problem. The other night we had lightning and rf6, wrgb, low band, was going nuts, I tuned to a more stable UHF OTA, and my Sat viewing was OK. Anyone else notice this? (722)
Yes. Same thing here.
Ed
I now have the same problem, so I will also delete the problem OTA channel,
I am glad I read your post.
722k Receiver OTA Problem (multipath) in Los Angeles
QVC in HD?
