The "Input/Pair" button, fail? | SatelliteGuys.US
tropez
37
United States
On occasion I need to change inputs on my TV. When I hit the TV button at the top of the remote for TV "mode", then it the Input button (which is also labeled pair), it does not work as I would expect. With other remotes I would get a list of inputs on the TV since that was the device "mode" I was in. I have yet to find a way to do this with the Hopper remote. I would like to figure this out so I can abandon my OEM TV remote and get it out of my living room. Any ideas, or am I missing something?
As we all know whenever they change the remotes they fix one thing for some TV models that break it for other remotes.
Find a different code for your TV using the remote manager, or, utilize the learn function. You're offered an option to add learned commands to existing code.
Menu->Settings->Remote Manager->TV Code->Learn->Add learned commands to existing code->Start Learning.
Instructions are well laid out for you on-screen. At least you have the OEM remote. Biggest issue as a tech when programming customer TVs on ViP Receivers is if there's no code, and they don't have an OEM remote, I can't help them.
In Remote Manager make sure Limited Mode is not Enabled.
Awesome! This fixed it. You da man!
How does PTAT and dish unplugged actually work?
I have to admit...
