the new 9 favorite channel screen | SatelliteGuys.US
bearingman07936
28
We really like it, on our HR21-700. So much so that I wish our H21-200 had it as well. Does anyone know if there are plans to add that to the H21-200 model?
One other question - this December software update "appears" to have helped the frequent freezes tremendously, that use to drive us crazy on the HR21-700. This is because we had only one line to it, and no SWM connection (we are long time customers - 13 years) It was terribly annoying and I noticed that there are far fewer, and perhaps they've gone away. Can't say that I've been looking for them, but I don't notice them anymore.
Did the software update also address the box constantly searching for feed from that second input?
Thanks.
Thanks.
When D* does an update they cover as much as they can as far as fixes goes.
As for the favorite channels being available in the new guide, I would imagine that you will probably get it on your other rec's. as well but there is no timetable for it to be implemented.
Jimbo
Problems with downloading guide data
Need help hooking up dish and receivers...
