The Tale of 2 Cities | SatelliteGuys.US
capndik
Here's my problem:
I live in Cincinnati with my family full-time. Currently, I'm in Virginia for business for 4 months. The house I'm renting already has a dish mounted on the roof, so I brought one of my receivers with me.
I hooked it up and it works fine, except, I have no local channels. It wants to receive the Cincinnati channels, obvioulsy, but it can't. The local channels here would be for the DC market, but it won't receive them either.
If it were just me, I could call dish, and change my address. But, I don't want the family to be without locals in Cincy for the next 4 months.
Is there anything I can do?
One person suggested upgrading to HD and getting a 622 receiver. He said it would receive local channels via the rooftop antenna, and integrate them into the guide.
I'd rather not buy a new receiver, though.
Thanks!
You could call up the cable company and get their "lifeline" package (or something comparable, normally gives you the locals, public access, and some shopping channels). It should cost $10 or less a month... then you could use your dish account for the rest of your channels.
Here's my problem:
Thanks!
Just get a set of rabbit ears from rat shack and plug it into the antenna port on the back of the reciever that you have. When your turn the reciever off you can then change channels on the TV tuner.
This will work provided you are somewhat close to the broadcast tower otherwise as the previous poster said... locals through the cable pig.
Power supply for sw64 same as sw44dp+ ?
160 GB 7200 RPM USB 2.0 External Hard Drive - My Book Essential Edition
