TheList AMC1 channels | SatelliteGuys.US
TTTTVVVV
17
Hello All,
I want to watch the Football Hall of Fame game on August 3. It is on NBC at 8:00pm.
Can I pick that up on the NBC channels on AMC1?
Rick
yes*
the * is because they are 4:2:2 so you need one of the following things to see it
-PC card
-DVB World Box (they hook up to the computer)
-receiver to do 4:2:2 (Quali-TV)
There might be a 4:2:0 feed up there somewhere ;)
yes*
-PC card
Thanks Mr. Iceberg,
PC-Card you mean like a skystar2 or twinhan or skywalker-1.
Do I need any special software on the PC for this 4:2:2?
Rick
yes like a PC card
as for the 4:2:2 question, I'd ask in the PC card area..folks in there know more about that than me :)
It really depends on the dvb application you use. For instance using tsreader with vlc will not require any additional codecs as vlc has everything built in. I believe most of the other applications will require a codec such as the elecard which can decode 4:2:2 video (or you could record the program using the application of your choice and play the recording back in vlc since vlc has no problems playing back files accessed by another applications).
Paul
FTA sort-of Newbie
Fortec Classic NA started asking for a PIN.
