Thelist for dish 110-119 missing entries after 8411 | SatelliteGuys.US
TimTechtoo
Ontario
Is there a problem with thelist for subscription channels generated for dish network 110, 118, & 119? The generator doesn't produce any channels after 8411. This started sometime after 7/5/12 at 1:16pm EST.
It looks like there is a problem, I checked the database and it only has up to channel 8411 as you mentioned.
Thank you for pointing that out, I'll PM Scott.
Bad SW 21 switch
If Dish drops AMC, will you drop dish??
