B BennyT Active SatelliteGuys Member Original poster Aug 8, 2010 19 3 Indiana Sep 9, 2012 #1 Right now my locals are on transponder 5 and satellite 129. I want to "move" to Terre Haute, IN. How can I check if I am in range? Also, when I do move do I need to change any dish settings? Sorry, I'm new at this.
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,335 14,679 Mankato, MN Sep 9, 2012 #2 Terre Haute is on 129 TP12 the spotbeam covers most of Indiana http://www.satelliteguys.us/thelist...&sub=true&sort=&order=&beamMap=CIEL2_SB30.jpg Also, when I do move do I need to change any dish settings? Click to expand... no. Other than maybe your favorites for the new locals
B BennyT Active SatelliteGuys Member Original poster Aug 8, 2010 19 3 Indiana Sep 9, 2012 #3 Iceberg said: Terre Haute is on 129 TP12 the spotbeam covers most of Indiana http://www.satelliteguys.us/thelist...&sub=true&sort=&order=&beamMap=CIEL2_SB30.jpg Click to expand... Should I be looking at the yellow boundary or the green?
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,335 14,679 Mankato, MN Sep 9, 2012 #4 the green is good the yellow you may have low signal just check what it shows on the receiver menu 6-1-1 then change satellite ot 129 and transponder to 12....make sure it says "spotbeam" when it locks
B bigrich SatelliteGuys Guru Dec 14, 2005 143 0 Sep 9, 2012 #5 If you are in Indianapolis, Terre Haute works fine.
