IntelPennny4 SatelliteGuys Pro Original poster Oct 28, 2016 326 124 USA Mar 20, 2018 #1 i want to use one of my 36" dish that i use for dish long time ago and want to buy this lnb but dont know if it will work for me Attachments s-l1600.jpg 57.8 KB · Views: 261 s-l1600.jpg 42.7 KB · Views: 266
M Magic Static SatelliteGuys Master Lifetime Supporter Oct 12, 2010 7,498 4,853 Montana Mar 20, 2018 #2 It just might. Let's see a picture of the dish and original LNBF to be sure.
IntelPennny4 SatelliteGuys Pro Original poster Oct 28, 2016 326 124 USA Mar 20, 2018 #3 i believe i post the picture before not sure Attachments DSCF1858.JPG 117.2 KB · Views: 240
M Magic Static SatelliteGuys Master Lifetime Supporter Oct 12, 2010 7,498 4,853 Montana Mar 20, 2018 #4 It should work. Just replace the LNBF not the arm extension. The old LNBF is a "D" mount, but the new "Square" mount will fit.
IntelPennny4 SatelliteGuys Pro Original poster Oct 28, 2016 326 124 USA Mar 20, 2018 #5 just what i thought im going after 121w ku
Cham VE4GLS Pub Member / Supporter Dec 19, 2008 2,565 1,140 Boonies Mar 20, 2018 #6 Yes that LNBF should be linear and work for FTA. Good luck on 125W, it's a must-have for any FTA installation! Reactions: Phalaenopsis
Phalaenopsis SatelliteGuys Pro Nov 24, 2017 457 275 NA Mar 20, 2018 #7 Yep, It works very good. I have the same LNB on my modified dish network 1000 parked on galaxy 3C. It's been working very good for me. I also had it on my wineguard before. Reactions: olliec420, FTA4PA, KE4EST and 1 other person
