I found this dish today.i asked owner how much he wants for it.he said $200.im going to get both satmex satellites.i didn't measure the dish but I think it's a 10 footer.what do you guys think?
Both dishes look good, the last one the better.How about this one? It's free lol.i went driving around nearby and found a guy with this satellite.he said free take it.im going to give him alot of beer.
What would be best way to dismantle and take home? Just remove dish from pole and take apart the panels? Im going to take the pole too.might as well.
ok so we split the dish in half and took it on the trailer.the only bad thing is the bolt broke off from two lnb arm holder or whatever its called lol.i was thinking of telling my brother to weld new bolts to the damaged ones.
That might not be so easy to repair properly. The threaded rod welded to the LNB feed arms ends looks like aluminum and the nuts were uncoated or zinc plated steel. (that's probably why they broke cause they were rusted solid to due dissimilar metal corrosion). Is it possible to weld steel to aluminum? If not then he'll have to get more aluminum threaded rod (maybe expensive or very hard to obtain ).That shouldn't be too difficult to repair. If you have someone to weld another bolt to the feed arm, it should work just fine.
Limited time offer
