Hi Magic Static,
I am using an Openbox s9.
Original software.
Anything else you might need just ask.
First, make sure you're on the correct Satellite by pressing the "OK" button and scrolling right or left until AMC4 shows.
Then:
1) Menu
2) Scroll down to "Installation", Press "OK"
3)Scroll down to "Transponder List", Press "OK"
4)On the remote, Press the "green" button to bring up "Add TP"
5)On the remote, press in the number you want, in this case, "3953", then scroll down to highlight "Symbol Rate"
6) Type in the number you want, in this case, "2734" then scroll down to "Polarity" and highlight "V"
6) Highlight "Save" and press "OK"
7)Press the "Blue" button to scan.
I use my 922 to adjust satellite position & skew. Once I'm on the correct satellite, I guess at the skew when scanning by placing my 922 on channel 1 . If I get nothing, then I change my 922 to channel 2 to change polarity and try again.
